You're not doing it twice, this is just information gathering...
I have yet to find a conversion pinout diagram that converts a 4 plug directly to a 3 plug!
Maybe I'll draw up my own once I've done it and ironed out any bugs, then post it up for all to use ;)
Sweet as.
Just to add also, when looking for your ECU, you'll most likely need the AFM that suits that ECU, and even injectors if your going STi ECU.
Yep, it's also been established that the 4-plug plugs plug into 3-plug ECU, and there looks to be an equal amount of re-pinning to do (about half ish) So really, i reckon it would be foolish to go with 4-plug ECU, when you can get a 3-plug in there with the same amount of hassle. The one thing about the 3-plugs are you will need to get yellow injectors, and a compatible air flow meter.
Wiring wise, take a look at this PDF, and the northursalia link above
ECU Pinouts BC5/BG5a/WRX 4-plug.pdf
Also, the GTB 3 plug is the same as the impreza 3plugs, only it has 4 ignition wires not 2. Regardless, it may help to have both. i fount the little diagram at the top of the gtb one very handy
97-98 ECU pinout.pdf
 teamnicknz said:
Oh dude u got the same ecu as me 7c but mines yellow (dunno what that means) im making an adapter up as well to suit the v3/4 sti ecu i think ive almost got it all sorted apart from a couple of things, will keep u informed.
thanks dude!!
 ReubenH said:
Yep, it's also been established that the 4-plug plugs plug into 3-plug ECU, and there looks to be an equal amount of re-pinning to do (about half ish) So really, i reckon it would be foolish to go with 4-plug ECU, when you can get a 3-plug in there with the same amount of hassle. The one thing about the 4 plugs are you will need to get yellow injectors, and a compatible air flow meter.
hmm not sure wat to do now . could get expencive having to do injectors?
Nah you'll be sweet if you stick with an ECU from a standard WRX or Forester, you only need to upgrade injectors if you're running an STi ECU and turbo. I might have a spare Forester ECU if your interested, PM me.
What Turbo are you currently running? Mine is just a VF10 and it goes quite well running on the greys and Mines TT ECU!
i was runing a vf8 .got a downpipe made.
but i bew the turbo up on sunday (guttd!!) theres a nasty noise from the turbo like the bearings gone.
so im looking at replacing both now. i might aswel do the lot now ae? save me from having to do it later haha
ive put up on the wanted thread that im looking for a turbo to but dont no weather to go for a tdo4l .
anyone know anything about these turbos . is it better than a vf8?
A TD04 is smaller than a VF8, about the same as a VF10 so it spools up quick quite low down but then runs out of puff at higher RPM. Theres a few TD04's selling on TM, in fact I just sold one last week for $60!
Well the whole point of upgrading to 3-plug is the injectors and tune of the STi 3-plug ECU's
I'd only go with a fozzy ECU if you planned on upgrading to the STi and yellows later.
Oh and get a VF39 au, they haul :P (i got mine for $300 from a guy named paul, i can give you contact details if you want)
That's what my plan is - convert to 3 plug and use a standard WRX/Forester ECU while I still have my EJ20H (std cast pistons etc) in the car, and then when my forged STi engine rebuild is complete I'll upgrade injectors and use an STi ECU with a decent turbo.
keen if it fits? wat sorta setup would i need ? and wats a vf39 out of?
VF39's out of the USDM 2.5L STI till 06 i thinks. It pretty much has the same flow rates at the VF22 as far as i've seen. TBH, if you could find something like a VF24, that would probably be a very good option.
    574.7k
