ha thats funny
boost cut on a forester is 14.5 but i took the hose off the waste gate actuattor and i boosted 20psi whats with that?
i also put on a boost tap and i was boostin 15psi (but i hav turned it down now)
 CUDDAS said:
Are you kidding that is freekin awesome.. :D
Na man that's free boostin, i'e you are blowing a lot of hot air at those psi levels & while it might be pretty wicked it's gonna kill your subie one way or anther.
If you have lashings & intend it to break, well go for it & post up some vids. but really man i wouldn't aye
ha im not gng to kill it doesnt boost cut at 14.5 its spose to isnt it?
Guest itsgotgo
 DRFVDR']
[quote name='zarnah said:
how can it cut boost when you have the hose off the actuator, dur
It can still boost cut as that is controlled by the MAP sensor and cuts the spark/fuel
he has proberly disconnected the map sensor as well :)
where as my rx dont got a cut :)
the map sensor vac pickup is on that loop he has disconnected,i think.
My one never hit boostcut when i took it it off,just kept climbing :)
 WRXER said:
Kept it off mate, so we can all place bets onto how long before something goes bang. ;D
Freeboosting... If ur hitting 20psi then ur engine isn't cutting out like it's meant to=Bad things tend to happen
Yeah, like Chernobyl... Those cheap Russki's took their wastegate hose off to make more power and look what happened there!
I'm pretty sure this is how mine is done, years & years ago now, i removed the hose to the "fuel cut sensor i called it"
it's attached to that boost solinoid/igniter bracket on the strut tower. I can't remember if it was tee'd into the turbo/wastgate line or if it ran from the inlet manifold. But it stopped my fuel cut.
Use to freeboost my vf10 & it broke crownwheel & pinion shaft when it got traction.
Sounds like some hard launches to me ;)
my foz also hit 20psi+ with wastegate hose disconnected (was checking for leaking bov\wastegate) and held 15 without cutting with a ebc, only ran 15 for a cruise to whangarei then removed ebc. Then i've hit 14 on a cold morining going to mt ruapehu and boost cut kicked in..... i think foz's have a mind of their own.
hard case im currently boosting 7 pound but it sucks so im gng to boost it back up to 11 maybe 12 ;D
Guest itsgotgo
 jasonv6']
Some one has removed the pill,at a guess :)
Waved out to you coming outa thames yesterday tintin,your foz is looking good as always ;)
 itsgotgo']
I waved too, your scoop stood out a mile away!
 pappu']
[quote name='jasonv6 said:
yea 7psi sucks ive turned it up to 12psi now :D
do u have a tap in there to run 12?
yea a boost tap can go to 15 but not lol
  • 4 weeks later...
Spend some money on making it safe to run that boost, you have to remember that its only tuned for standard, now that your playing around with it u r decreasing the engines potental life span lol
