VF39 heatseild
ReubenH
Every so often my clutch pedal gets all slopping, almost similar to brake fade type sloppy when you start boiling your fluid. After some talk on the forums about not having a heatsheilds on ya turbo, i put two and two together. Is it possible that the turbo is heating up my clutch fluid when it gets nice and toasty? Would that actually cause the clutch to go soft, or would it have a different effect?
I never bothered replacing the heatsheild on it after the single conversion, cause we kinda munted the old secondary ones comprehensively while getting them off (I was frustated with with working with TT's :P) Will any heat shield fit? can i get away with only sticking the top one on - it's just too much hassle having both on...
The turbo as is now:
i might have to go hunt one of them down too. my VF36 makes my pedal go a bit mushy after a good raping sometimes, just never really thought of it (my old twin turb occasionally did it too).
get one of them turbo blanket things au. although, probably cheaper to make your own heatshield from sheet metal than to buy one of them.
