A bit of help for a noob
 iSLIPT said:
Lol i have $1 right now if you have the engine! hahaha
sure thing, it has an engine. and all the other bits too, he drives it every day... but not after you buy it!
 Erelyes said:
Got my V4 STI coupe (type R) for $7200, but its a little rough here and there. Came with some fruit though (exhaust, external, front mount, ECU). Seems to be a bit of a jump in price to V5's and up though. Sedans are definately cheaper and wagons cheaper again. STIs of course command more than WRXes.
What to look for... the usual things really.
-Rust (boot, chassis rails, sills, firewall, A/C pillars, around windscreens, etc)
-Leaks from rocker cover gaskets are common (crawl under the car and look at the ends of the engine next to chassis rails) - this can be expensive-ish to fix
-Any signs of overheating etc (if possible look at the car when its cold and check the header tank is full), they can crack the radiator endtanks sometimes, and blown headgaskets will usually end the motor
-Knocks from suspension indicating worn shocks (other than shocks subys seem pretty good for suspension reliability)
-Shuddering under braking (warped rotors, will cost a couple hundred at most)
-Check the DCCD works if it has it, turn it all the way down, do a U turn, it should be silent. Then turn it up to locked and do another U turn, it should clunk around a bit.
-Avoid anyone selling their car as a "singapore spec sti" ;D (sorry bit of a forum joke)
If it has a front mount, check if they've cut chassis to fit it.
There is also a good thread http://www.clubsub.org.nz/forum/index.php/topic,5731.15.html here, post number 3 will give you an idea on different facelifting of the GC8's.
Good luck and have fun.
Also - when you view a car, jot down the VIN from the firewall, so you can check it matches the plate! Plus you can call your local friendly Subaru dealer and check what sort of spec it really is, as they can tell you if it's actually an STI or not.
FIRST thing you do when checking out a car is take a good long look at the owner!
If the cap is on an angle, walk away... :D
If he/she uses the words Boost, or Boosting as an adjective, walk away...
Next, look at the car:
If it has any of the plates on an angle, you guessed it, walk away...
If it has more than 3 parts/brands stickers on it, then walk away...
...and, most importantly, if it is described as a special edition coming from Singapore, laugh in his/her face, and then walk away...
;D
Reading that just kept making me think of that ad on TV....spray and walk away! lol serious tho, wen I sell my car I think i might steal someone from here to come look at some cars with me one weekend, it might be a bit easier
One way to score the car you are after is to find one that some redneck has blown up, some thing really serious like a BEB where-by they cant afford to fix it themself. As long as the body and interior is mint or has the potential to be.
If you are mechanically minded and/or with the extra cash you saved from buying one that is blown up, you can pull the motor and get it reconed or buy a replacement engine with bonified KMs, then do the clutch, W/pump, oil pump service, cambelt, tensioner, idlers, and get the radiator flushed etc etc.
You can inspect, clean and service the lot!
That way you know what you have right from the get go, otherwise there is always that shadow of doubt and/or chance that your poor old EJ20 has been totally raped, modified by a complete muppet and never been serviced, even if the dude that sold you the car looks like he's telling the truth that its "never been thrashed".
Plus all that helps with re-sale
Thats my fiddy
Sort of what I've got on my hands as above. A $350 BC5 assumed to not work. Stuck in drive and refusing to run. With a car in this state, assume it will need an entire powertrain swap and go from there...with a mint body you can't go wrong :)
Im aiming to get something standard thats good to go, the past 2 years has been spent doing up/maintaining amd fixing stuff, i can be a$$ed with that anymore lol
