STI VERSION 7 SHIFTLIGHT & RPM SETTING
LUMMYSTI
Hey guys just wanting your knowledge on what rpm i should set my version 7 sti shiftlight rpm setting at for best performance!! i have no idea lol, car has done 122,000kms i got it at 89,000km and had no idea that the shiftlight was a feature on the version 7s lol dumb i know!!
Got mine set at 6,500 rpm. Gives you a bit of over run before hitting the rev limiter.
To be fair, when I am driving a tight bit of road I never hit the shift light/beep anyway and generally change around the 6000 rpm mark (which is the lowest setting for the shift light.)
thanks treecrusher, does it depend what your boosting at? im running standard boost
 Treecrusher said:
Mine is completely standard, so guess it will be the same.
Wouldn't think boost would make much difference anyway as peak boost would be obtained well before 6500 rpm even if you were running it higher.
mean treecrusher!!
yea 6500 is pretty good..
burt if i want the passengers to feel most acceleration thru the gears i do it at 5500 ..seems to get more "push" in the seat feel..
although the 6500 may be quicker on a timed run..
choose the one that suits u and try both lol..
yeah i think i like 5500 just so i can see the it light up more often lol
thanks guys!!!
 LUMMYSTI']
thanks guys!!!
The min I can set my light at is 6000rpm.
why dont you drive your car and feel when it stops producing decent torque? as that is when you want to be shifting, anything else is a waste of time oh and btw, fyi... dont listen to everyone elses i set my light to 6500 as everyones car is different, its not a guide. its a personal preferance. omg
yeah i hear ya mate, i like it at 5500! omg!!!
yeah i was just taking the piss haha. but for real. just drive it till it runs out of torque and then shift. you will feel it. then you can set your light.
you wana be coming onto the next gear at good revs tho - change smack on "peak torque" and you run the chance of falling to far back down the curve - if your being technical ;)
 Me Old Wert said:
Um I got a NZ New V7 STI and my light or beepa does'nt activate? How do you set it?
Both don't work?
when the ignition is on but not cranking the engine, (2nd turn), twist the stick thing and it will say like 68 which is 6800 revs then it will beep i think. Then it will say on or off meaning the beeper sound.
