gt3076r yay nay
off2harrys
basically how would this go on a ej2ot i know it would be a bit laggy would there be much difference between my vf22? heres a link http://www.trademe.co.nz/Browse/Listing.aspx?id=206644066 ,what questions do you need to ask when buying a turbo?which turbine housing it has etc (my belief is the smaller the housing the faster the spool?).whats usually involved in fitting 1 of these just modifying the up and down pipe and oil lines.my cars a v2 rex.cheers
Guest loren
 QUIKGT said:
Um yeah, what he said.
But you'll hit boost around 5000rpm....
nah, not that high surely, it's for a 2.0 to 3.0.
a 3071r with .64 housing is far more recommended then the 76 for overrall response, I wouldnt be suprised if u had lag til 5000rpm. Hence why most people have gone with the 3071r. Im personally going down the tried and true method, I really don't wanna blow money into something that will probably not suit my needs with the use in trackwork.
GT2871 develops 1.0 Bar at 3800 on a well tuned EJ20, and will happily spool up 2.0bar :)
Have found this turbo to be the best performance and streetable turbo in the Garrett range
I had a GT3071 with a .86 on my 2.0lt MY 98 WRX motor.
Didn't make full boost (20-22psi) till 5000RPM's...
Was a pig.
Turbo was originally on my 2.2 and made full boost (24psi = about 260-270kw's ATW's) by 4000RPM's - was much nicer to drive with.
A GT3071 with a .6 would be good on a 2lt if the engine was forged, had decent cams and drags was the sole aim.
For a good daily driver with go a GT2871 would be better.
For a bare short motor about $2.5-$3K AUD depending on which rods and pistons you go for.
Heads; depends on if you use your own, which just involves the cost of getting them prepped by a head specialist (cleaned,faced and pressure/vac tested) and the cost of a pair of head gaskets, rocker cover gaskets and cam seals.
If you don't have heads then it's+ what the heads cost to source
