What Speakers ???? 98 WRX hatch
KING PIN
??? hello everyone was wondering what sorta speakers sit in the 98 wrx wagon doors? are they 6 or 6 n 1/2 in all four doors? i am wanting to replace them all with pioneers but wanting to know if anyone knows what size go in them?
any help would be greatly appreciated.
Japanese 6.5" (16cm) speakers will fit. i.e. Pioneer, Sony, JVC... American 6.5" speakers i.e. Alpine, Rockford Fosgate, Boston, JBL... which are true 6.5" (17cm) will not fit and require aftermarket spacers
Most subaru speakers manufactured after 1998 are a single one-piece molded plastic spacer/speaker, so u need spacers anyway
A lot of manufacturers also do a multi-fit OEM speaker usually in the form of a 2-way coaxial designed to fit factory locations.
Wagons generally have 6.5" in front doors and 4" in the rear ones
Yep what spark_38 said, except for you don't always need new spacers. You can hack up the plastic factory spacer if the magnet is too deep, just cut the angled back part off with a hacksaw. Or the last time I did it, I broke it off bit by bit with a large pliers haha. I installed a set of Pioneer speakers and they went straight in.
  • 5 months later...
 gemini said:
So not worth trying to squeeze a 6.5" in when a 6" will do. <speaker, that is!>
So without sound deadening would I be wasting my time hooking door speakers up to an amp?
If you amp them they will still go louder with more clarity. you just dont get the bass. But thats not what those kind of speakers are for anyway. Idealy you would have some kind a low pass filter cutting the bass from going to them and running a subwoofer instead.
Is it really a sub, or just a 6x9 that is high-passed to only play frequencies lower than 100Hz(ish)
The best subs for space restriction are the flat piston types, Pioneer for example.
Personally I don't bother with rear speakers... why give passengers music? It's your car!
If you do your front stage right, then it will immerse your car in sound anyway.
It's only a small cabin, not like a house living room or movie theatre.
Where do you put Pioneer flat piston subs?
