V4 heads on 89 block
Ryan
Pistons different from what?
Easy way to group Imprezas.
Mechanical/exterior: v1&2, v3&4, v5&6. The differences in general tend to be minimal WITHIN the group, but QUITE different between the groups.
Interior: v1,2,3 and v4,5,6.
The thing that stops the 20K heads from fitting a 20G shortblock is the pistons. Put the appropriate pistons in and that's one worry solved :D
^ninja edit. Disclaimer: simplistic, generalised view.
 Koom said:
Usually when you're buying off the shelf pistons for EJ20's there's pre-98 and post-98. I used pre-98 with my V3 STI heads, I'd guess V4 is the same as the change most likely occured with V5.
Yeah i think your right there Koom from what iv been told its v5 that had the change
