starter motor
G-unit
  • Replies 58
 gazzy2000']
[quote name='G-unit said:
i took it to the electricians 2 fix, i just removed it, they fixed the plunger and bearings
Oh ok, they must have checked all the other stuff... surely,
id ask them if the did infact check the brushes and take it from there
If they havnt yr ganna hv to take if off again :'(
actually if they have done the armature bearings they wud have seen the brushes, and from my experiance those str mtrs dont wear out the brushes much.
I have seen an intermittant short in the windings of the solenoid on those, i wonder if its worth getting a cheap S/H one and swaping yr known good bits into it?
heres a trick, run a wire straight from the batt postive to where the wee wire goes on to the str mtr (the one from the key) and see if it starts then (watch you dont short the wire on any thing)
This will bypass the starter relay and/or votlage drop from other starting components (ign switch)
 G-unit said:
oh bloody thing, wat can i do 2 fix it
haha, yea painful aye.... um ring the sparkys that did the str mtr and tell them u still hv the issue and ask them if they checked the brushes, the armature for shorts, the drive and its bearings etc etc
most sparkys check all these things by default just make sure.
ANd if yuu have to take it off again, you are going to have to check the ring gear on the FW for bad buring and file if need be (painful job)
Failing that get a s/h str mtr and swap all your good bits into it
yea, im in a small town so will have 2 wait till monday 2 get down 2 see them, wont start again now, just went and made sure everything was on starter tight, u gota pic of what mine should look like? it has a green sticker on it
mine looked like this
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Subaru/Electrics/auction-267768622.htm
