small Simota breather filters
wildturkey
I've noticed a few engines running the 25-30mm mini breather filters straight off the idle air control, crankcase breather outlet, and rocker cover breather outlets............seems to get rid of quite a bit of the factory breather piping
Im just assuming this causes no issues with idling or engine breathing in general. If you know of any reason not to do it .........can u post up cause i'm looking to do this and lose sum of that factory breather tubing in the process.....cheers
You'll find those doing that are running an aftermarket ECU (i.e Link etc) so they don't require the idle are control valve, Not 100% sure with your piggy back but you might require the use of it still
