injectors
  • 3 months later...
 kingersman said:
and a lot of force to get them out!
nooo not usually - you break them if not careful. If the rails are out, get a large flatblade screw driver and wedge between the rail and the plug lip gently, use a thumb to apply some pressure from the bottom at the same time and it will leaver out gently.
People also use a pliers method.. but i havent done this myself as every effort I've done personally seems to pit or damage the plastic's on the inj. People do do this successfully - maybe my technique is poor .. i dunno.
 funkytown']
yes its all technique!!! ahaha also condition of plastic..
Guest boostin
 kingersman']
Twist and pull boys, twist and pull....
