Are most sensors the same through the models?
Guest vf20/21bg5
...are the crank,cam,knock,water temp and any other sensors all basicly the same?...my situation is i want to use those things and a couple other bits and peices off my 96 GT tt engine for my fordged closed deck block build with v5 heads/twisted/link etc
Will i have any issues? or are they all interchangable up to about 99/2000?
Crank and cam sensors are the same all the way from 89 to 2000 and even beyond. Knock sensor is too except the later ones had a different plug but you can just un-pin it and clip it into the other type if you want to. Water temp is the same from 89 to 97 (although placed in different locations), there are 2 separate sensors 1 for ecu and 1 for the gauge, the later model then conbined the 2 into just the 1 sensor (a 3 wire sensor). Most or maybe all other sensors are different. AFM definately different, ICV different, TPS different, MAP sensor different. O2 sensor stayes the same but the plug changed.
