1S ECU - what is this one out of?
gazzy2000
 JoKer said:
http://www.clubsub.org.nz/forum/index.php/topic,9493.0.html
VER MODEL SPEC TRANS ECU ECU PART AFM MAP NOTES
Ver 3 GC8 D WRX MT 1S AC721 D55 E AA271 Orange AA090 VF22 EJ20K Yellow Injectors
yea search aint so hot especially with less then 2 characters! (1S)
yea thanks, i saw those 1S ECUs in Kaminekos thread, but the numbers on this ECU are slightly different and not in his list.
So i guess the question is... do all 1S ECUs (regardless of teh other numbers) run yellows etc etc
on this one the model numbers are on a black lable
 Leighos said:
I've used an ECU with that exact part number in my single turbo conversion, using orange airflow meter and yellow injectors and it ran fine so I assume it was the correct combination.
Using a 6S now, much better ;)
cool thanks, do you reckon the 6s was a noticeable differance?
 funkytown']
[quote name='Leighos said:
Yes noticeably different, I think the 6S has a higher rev limit also, but I'm not game to test that out.
I can confirm that a 7S will rev to 8200, constantly, persistently, and forever :)
even on a WRX block?! ;D
I don't think so Jon. But on a STI block - yes. ;D
Looks like I meant a 75 - not a 7S - my bad - blame it on the poor eyesight. :)
  • 3 weeks later...
GODDAMN i love these threads :D
 gazzy2000']
hey, i used the search and found nothing on this ecu, can anyone help?
1S 22611 AC720
A18-000 D28 6Z10
i know its a 97 GC8 but thats all, does it run yellows and a orange AFM?
cheers
YES. That ECU listing has all the info you need, have a read further down. quoted for truth :P
Ver2 GC8C STI-RA MT 7K AC710 D22 AA160 Green
7K = reference code for easy identification.
22611 AC710 = This is the Subaru Part number for this ECU.
22611 (ECU part category)
AC710 (Part revision)
A18-000-D22 = Unisia Jecs part number. (Jecs builds the ECU for Subaru)
D22 (Part revision) this number is usually found on a sticker on the socket. This ties the
case to the ECU board. [up to version 3 afaik]
5X11 = ECU serial number
note: sometimes the ECU revision may be out by a few numbers eg. AC710 -> AC711 This is the same ECU with a minor revision, possibly to the tune.
its the sti ecu, 8200 rpm limit. your wrx heads wont like that very much :)
yeah that defiantly be a 75 unless it was a aftermarket modified 7S
