95 subaru wrx engine knocking noise
i was wondering if some one could help me, i was driving along the motor way and my car started surging i pulled over and it died, started it up again and a knocking noise came from the engine left if for a few days started it again knocking was still there then car died.
Please help
Interesting.. :-\ So the engine must die when the bearing fully sh!ts itself..
And to everyone thats reading this and had a BEB. Did your engine die/stall/seize before BEB knock?
This should figure out my mystery question lol. sorry guys im just REAL REAL bored!!!
i was just crusing along at 100km/h came to a 70k zone, slowed down to 70, cruised through the 70k zone, got back to a 100k zone and as I accelerated (nicely, just crusing) the engine zust went NUGGA NUGGA NUGGA NUGGA NUGGA! and it got real loud by the time I had slowed to a stop, managed to drive it a couple hundred metres back to a petrol station I had just past, it was still idling but sounded horrible, turned it off. the end
have just towed it back from where it has been parked up for a few weeks started it and it died started it again and it idles but still has the knocking. what would of caused the cutting out/surging before it started making the knocking noise
knock sensor telling ecu to change timing etc probably
 beezy said:
so what are my options what would i be looking at to get it fixed is it worth it?
1. rebuild, around 3k for a quick build using factory parts but all new bearings, seals, second hand crank etc etc
2. forged rebuild, the sky is the limit on pricing here
3. drop a second hand engine in, anywhere between $500-$2000 depending where you look and if you can do the work yourself
It all depends what you want to do with the car, if you want to maybe keep it and continue to use as a daily driver without modding it to much etc I would go with option 1, if you want to build it tough and do a few mods etc for decent power then go for option 2, and if you just want to get rid of it then go for option 3 chuck a second hand engine in and flick it off
