weird, burning smell?
clintondane
hey guys, we've got an '01 blitzen sedan and just recently i've noticed when i stop after a decent run at normal speeds there's a weird burning type smell coming from the engine bay. there's no smoke, nothing dripping etc. only thing i can think of is a while back the radiator hose blew off thanks to a dickhead mechanic and the engine bay was splattered good and proper with coolant. i thought of steam cleaning it but was advised against that? the thing is, coolant generally has a sweet, heavy smell whereas this smell is more like rubber or plastic burning. weird? any help or suggestions appreciated.
Guest S T  E Y E
yea ull only tell by sussing it out/ looking at it...
the only rubber/plastic i can think of is either ur o2 wiring on the exhaust or a vac hose on the exhaust or the fan wiring on the x pipe by the radiator???
hmmm come to think of it i had a sniff the other day and coulda sworn the smell was stronges near or around the radiaor. taking the car in for oil change and service this week so will get them to check it then. not affecting the car so not panicking, thanks for the help.
on my car one of the hoses going to the water pump has a small weep. this drops onto the headers but gets burnt off almost instantly could be where the coolant smell is coming from. also if your radiator has been replaced water pumps are prone to start to leak. just a thought
got the car back from serviceing and turns out the odd burning smell is coming from a split inner cv boot leaking grease onto the exhaust :-\ gotta book it back in to southern subaru, quoted $145 for parts and labour. sound like a good price or worth shopping around?
Not bad price for Subaru. I just brought two new inner cv boot kits a couple of weeks ago from Ripco and they were nearly $30 a kit ($60 total). Was lucky though that there was a welly member prepared to put them on for me.
