Gauges on bonnet
wrxboy
 zarnah said:
not sure about cert but im pretty sure you gotta get "knob" tattooed on your forehead to have gauges on your bonnet
yip thats mandatory......
iirc you have to write it backwasrds so you can read it when looking in rear veiw mirror :D :D
Guest vf20/21bg5
you will only have issues if it has sharp points...and if its going to hurt somone if you hit them front on...well that was the case when i was issuing wof's...otherwise no problem
My mate has 3 gauges on the bonnet of his RX3. They've never given him any issues getting warrants or when the plod decides to have a closer inspection on the side of the road..
The real test will be when he goes to get his pink sticker off at VTNZ haha
Guest vf20/21bg5
Thrs no issues with them honestly its like having an emblim on the front of yr bonnet, as long as its not going to cut or maim anyone its all good
As soon as the cop got to the window, he said "I'm going to pink sticker this car for something"..
The rear was 3-4mm below where it should sit (according to the cert plate) and he deemed it 'too loud'.
Guest S T  E Y E
IMO gauges on the bonnet of a subaru is a crime...as too if they were on the bonnet of any newish car...
but i think gauges on the bonnet of say a rx3 or some old muscle car looks pretty tough
Guest S T  E Y E
such a controversial topic the whole cert thing aye... it doesnt need cert...it does need cert haha
the main reason things that actually do need cert pass wofs is because half the guys who do wofs (even at vtnz) dont know the rule book inside out and cant be bothered checking up on modifications (if they even notice them at all)
http://www.nzta.govt.nz/resources/virm-in-service-certification/virm-in-service-certification.html
The risk of a component (Note 2) hooking a vehicle, or
hooking or grazing a person, has not been minimised,
eg a bonnet or bumper has been removed, exposing
sharp, moving or hot components.
2. An ornamental object or fitting (Note 1) protrudes in
such a way that it is likely to injure a person.
3. A protruding object or fitting that has a functional
purpose (Note 1) is not installed so that the risk of
causing injury to a person is minimised, eg the object or
fitting:
a) is of excessively heavy construction for the purpose
for which it has been fitted, or
b) has sharp corners, or
c) slopes forward, unless this is necessary to fit the
contours of the vehicle, or
d) has an unnecessarily wide gap between the object or
fitting and the front of the vehicle, or
e) exceeds the vehicle’s width by more than 100 mm
on either side, other than side mounted glass sheet
transport racks and collapsible side mirrors, or
f) is a glass sheet transport rack that is not fitted with a
front flaring to minimise the risk of injury to a person.
4. A protruding component, object or fitting is not securely
attached to the vehicle.
5. A protruding object or fitting adversely affects the
driver’s vision or control.
Guest vf20/21bg5
fitting:
...............SEE IM NOT FARKEN DUMB! ....i did once issue wofs b4 i was a trade certified mechanic and as i said b4 in my 3 othe posts here......if it has no risk to the person nearby or by the person being bowled by that car it is not an issue!...it doesnt take a rocket scientest to know this
So print it out and take it to them, surely they can read.. Don't be too rash about it, otherwise they'll get their backs up and tell them you to fark off.
Make them know that you feel as if you have been unfairly and inconsistently penalised for something which is fine in terms of the law.
Guest vf20/21bg5
yep if sumone on here has failed a wof due to your round,soft,plastic guages being on your bonnet near your windscreen externally then say WTF,these guages wont maim or kill sumone! what right do you have?
I would've thought that you would've had the right to take the car back, along with evidence to support the fact that your vehicle has been inspected in an inconsistent manner, according to the NZTA safety requirements.
Surely even a testing station has a complaints resolution proceedure..
