Where to pass power wire for amplifer (legacy B4 2000)
chaminda
Hi
I'm wiring a amp and was looking for a place to pass the power wire (4 gauge) from under the hood into the passenger cabin.
Most people drill a hole through the "firewall"but i don't really want to do that (might end up failing my WOF!)
Any suggestions as to where there might be a hole already drilled?
thanks
Yes look for the rubber grommets in your firewall..
From memory I used one on the passenger side near the strut to pass a 0Ga wire through with no issues. To make it easy I removed some trim from the dash (the glovebox) as I am not a midget and cant contort either...
I normally use the rubber grommet that passes the two A/C hoses into the cabin - large enough for 0 or 2-GA easily! And multiple feeds too.
Since some remove their A/C system completely, that leaves even larger holes for bigger cables.
On some newer cars, I've found this to be blocked off by a small metal plate - but never on an Impreza chassis. Maybe on a late model Legacy?
BE/BH Models don't have this option. And probably not any of the later model Legacy's
 Scoobydoo']
thought so i could only ever find down near the pedal box, comes out behind clutch pedal.
