anyone recognize these plugs??
subaru-mania
under the steering collum of my project Rex im found these plugs/ loom , they have been spliced into a few wires , an are just standard black wires hence why i think there an old alarm loom?? could anyone confirm this or know what they are for? Chur
loom1.jpg?t=1299372135
Can see the ones i marked have been joined also above that...
loom2.jpg?t=1299372247
this plug goes into just below the Fusebox in the driver side foot well lower pillar
loom3.jpg?t=1299372413
  • 7 months later...
bump
Does anyone recognise these plugs? on my 96 v4 WRX sedan, they were not connected, not sure if there spose to be connected or not, car is not running, no engine at the moment so cant test them
 Mattapo said:
looks like avs wiring
Probably; it's not dynatron - as the LED wiring is in the plug. I suspect it's a Meridian - they are the crappiest alarms, and often tend to fail/blow/melt.... I've personally pulled at least 3-4 bad ones.
Also the install is very poor - both immobilzation points are on the same side of the plug and next to each other. I could bypass that in less than 30 seconds!
How can that be NZSA compliant when the rules state that immobilizer points should be at least 300mm apart, and not on the same loom!! And I'll bet it was "professionally" installed too.
There are two places in welli/hut that I've witnessed installs and I wouldn't recommend anyone go there. One of them do audio as well.
  • 3 weeks later...
Anyone help with these? Top 2 is 1 near the speedo cluster, Third one was cable tied by the front diff, but does not connect to anything at both ends, the other end is just coiled up in the engine bay right up by the windscreen on the passenger side. And the 4th are the four black ones next to the ecu reset ones. Cheers for the help
