v5 spoiler stuck
revolution.tdk
snap them off? i dont really see any other way but someone else might?
if its possible (not sure if it is) but if u can get access to the thread easily cut a slot in the end of the protruding bolt so u can hold the thread stationary with a flat blade screw driver and undo the nut with a spanner??
not sure if theres enough room to do this but just trying to help you bro
I would say that you are screwed, the bolts are rotating in the fibreglass :( choices are either rip bolts out of spoiler and then replace and fibre glass in new ones, actually regardless of what u do u will need to glass in new bolts :(
thanks all for the help! i got 4 nuts off with the vice grips and a spanner but the other 6 were impossible with that setup as the bolts were too skinny to drill into/make a slot for a flathead screwdriver to hold the bolt still and also there was only enough room to fit the socket spanner down there so couldnt get a good grip with the vice grips. ended up taking it to a panel beater and they got it off somehow, said they used a rattle gun and some sort of tool to hold it still. cost me $60 all up but all good!
