Noticed it started hapining last night but when i am about to park up or turning at a low speed the car starts to shudder :( any ideas on what that could be??
Hey mate yea it is an STI i have got it set at auto and it still doing it so u reckon its most likley to do with diff??
Not saying it definatly is but if its set up wrong it will do that at low speed.
Unless the controllers playing up but i highly doubt that never heard of one failing.
Yea is really odd that it only does it at low speed range and only when do a full turn. guess its a trip to the mechanics for me!
my uncles shuddered both ways and eventually bound up... turned out to be the bearings in the magnetic coupling were shagged, as well as some damaged wiring. he ended up forking out just under 10k, but he had the gearbox rebuilt and a new clutch at the same time.
your DCCD is tied into your hand brake, pull the hand brake slightly when its binding and it should let go. but if the bearings are bung it may not
I took it to SUBLAB and apparntly the viscus in the front diff is bung :( does anyone no anyone that noes quite a bit about subies and would be able to fix this??
