6.5" speaker crossover help wanted
TypeR rated
Hi guys. I bought a car last year which I'm restoring, The car has a nice pioneer bluetooth headunit and cerwin vega component front and rear speakers with all the wiring setup for two amps ( 1 for sub, other for speakers)
Now my problem is that when I bought the car from auction it has had the rear crossover boxes removed from previous owner, I have googled these speakers and hav found that they are highly rated for quality and I would like to keep them but I need some more crossover boxes.
My question to you is can I use another crossover network without ruining the speakers or do I really need to have the original boxes to use these speakers??
I have 3 sets of other components from previous cars and was just wondering if it would be safe to use one of those crossover boxes.
Thanks guys. Car is hibernating from the snow in storage at mo but I'll note the model numbers down next time I drag it out seeing as tho I've lost the bit of paper I wrote the numbers down last time. I'll try and look at the crossover boxes from the fronts an see if they have the freq range on them somewhere.
 Scoobydoo said:
Well if you want to run them actively off an amp, you can use the amp as the crossover for both woofers and tweeters. But you'll need a 4 channel amp, one channel for each speaker.
That is true, I hadn't thought of that. I shall look into that
You'll need a pretty decent amp to get tweeter-worthy crossovers onboard - you'll need something up to 4khz, and most amps use 18db/octave crossovers so it might sound a little funky. Ideally you probably want around 4khz 12db/octave but without a processor/high end headunit/original crossover you might have a hard time getting it.
