Trademe Legit Check
This is a useful site.
http://www.hksusa.com/info/?id=3646
Ask for proper pictures of the item and box. Then try and compare.
EDIT: Actually, if you look at that site and check the picture of the box.
Fake:Strip at the top is pink
Real: Strip at the top is purple
The ones in his auction have a pink strip. If the information is correct on that website, then the BOV's he are selling are most likely fake.
Yea the camera hes using could make the strip at the top look like a slightly different colour... I say theyr real...
The easy to spot:
The inside ring should say Sequential Blow Off Valve
The HKS stickers are already attached to the unit.
The Centre bullet is purple
The top ridge is raised higher than the outside cover.
The harder to spot:
Ridges on screws. HKS genuine units have ridged screws, some fakes do not.
Taking it apart is a sure way to tell because you can see the quality.
HKS also have a Counterfeit Identification Site: http://www.hksusa.com/info/?id=3646
