LSD?
FST4RD
 FST4RD said:
Hi all, looking to upgrade the rear diff on my 95 TT SW to an LSD unit.
Do all Legacy TT SW's have the same diff ratio? If not is there a way to tell?
Which LSD units from which Subaru's will fit?
Thanks
If its manual it should be 4.1. The old Rs leggys have LSDs and are also 4.1.
The best way find out what ratio it is, is to match up the gearbox numbers.
Was going to do the same thing but Im running 6 speed stuff now.
It'll have a viscous LSD in it already and the only real upgrade if using factory R160 parts is if you find a plate diff from an RA Impreza. I'm not sure when the swap between male and female inner cv's happened though? But thats not impossible to get around.
Next issue is that an R160 plate diff in a factory RA from the mid-nineties is getting a bit old these days and probably will need a freshen up.
Could always source an aftermarket plate diff $$
AFAIK all the version2 sti got the R160 mech LSD. the only rarity with the RA is the 3.9 ratio.
 DRFVDR said:
Just as a wee correction,it seems that not ALL TT wagons had Viscous rear diffs, i have scrapped 3 and 2 had open rear diffs :( they may have been swapped out earlier in their lives but most certianly open diffs
interesting, what revision & grade legacy's?
My old 95 BG diff is open? same with the 94 BD diff in another wagon I have? Both 4.1 ratio.
The gen 1 legacy lsd diffs have a sticker that says 'LSD DIFFERENTAL 4.11' most of the time which makes it easy to determine what it is :P.
Sweet will try that then! lol
Normally on all my other 2wd cars you just get a set of wheels off the ground and see how the spin. Obviously a bit different with a 4wd.
 FST4RD']
yes I think that works (correct me if im wrong)
With my BG 5 speed diff I can still spin it if someone holds the other side but my V7 STI rear LSD spins both at the same time.
Also, The gen 1 lsd's are friggin cheap compared to everything else, id expect $100 or less (plus installing it)
 dilly']
Nice... pity it's at the wrong end of the country...
Do you need the axles as well? or are the non LSD and LSD ones the same?
Nah axles are the same, you just need the diff.
no i would double check this beforehand, i've found the stubs to be different between open/viscous/mechical
 kamineko']
Yup this is correct,even little things like some have the circlip in the diff and some have it on the stub axle :)
Ask funky he had issues with his set up
