On Board Boost Cut?
dean.ryan
To anyone who's reading this.. lol
I'm driving a 97 Impreza WRX, EJ20 Turbo. What's safe amount of boost to pump in? I've put in a Turbosmart Boost Tee and it does spike up towards 18 PSI, where then the engine cuts out completely, is that an onboard boost cut on ECU or is it the engine just giving up on me?
Sorry for such a noob question, new here :)
Mine cuts at 14psi, so not sure what's going on with yours. Unless you've got a version four, in which case maybe you have a higher cut. Is the "engine cuts out" sudden and violent? If so that's boost cut. If not then it's probably pulling timing or something to stop itself blowing up
Well i've put a boost gauge in and it happily boosts at 14.5 PSI, but any higher and it just stops till the revs drop and the boost drops.. hoping it's a boost cut. But to be safe i've turned the boost down to 10 PSI...
Fuel pump crapped out and running a standard Impreza fuel pump now.. Pick A Part didn't have any boosted ones :(
are you able to hold boost over 14psi without it tappering off?
yeah sounds like the computers cutting into limp mode as its running out of gas being a wrx you'll have a tdo4? if your wanting more boost a recommend running an aftermarket electronic boost controller.
But be careful as you could lean your car out and it'll detonate and you can say bye bye to your engine.
plus you could melt a piston as well as wrx aren't forged internals.
I'd personally upgrade your injectors to yellows, ecu to sti, and turbo to one of the vf series then when you want more boost upgrade the internals to forged.
I'd be far more worried right now about the non turbo fuel pump not supplying enough and just blowing it up all on it's own. There is a reason there is a turbo one and a non turbo one.
The TYPE of boost control has nothing to do with this problem. You could just drill a hole in the wastegate line to run whatever pressure you want. If you have a boost cut of 15psi (or whatever) then just don't run that much, problem solved. But get the fuel pump sorted before you keep fanging it.
