So I failed a warrant today, he said "RH near control arm bush cracked"
when I got home I jacked it up and had a look and there was a liquid all over the housing and the bush,
Is this something the WOF tester has put on it to test it for cracking somehow or is it a sign of damage? I googled it and a forester forum had something similar but no clear answer,
The bush (the rubbery bit with the spline like texture) seems to be loose, i.e I can wiggle it with my finger, however the LH side one is the same and he didnt fail that? (doesnt have the liquid either)
Here is a photo ( sorry shitty iPhone pic)
yeah its a silicone filled bush, very common for these to leak. super duper easy to change and not very expensive. yes it is a Wof issue
forester ones shag out if you lower too much, they are silicone filled too. whiteline make a decent set i've heard, and the solid ra ones are supposed to be pretty good too.
i jsut get them from my local parts store. have changed alot in the 4 years ive been working on cars.
nope its all standard
I guess it's just worn out from wear and tear,
How much do they cost approx?
also I guess it's worth doing the front one as well? (like the smaller dia bush, on the same arm, closer to the front)
