Brakes redone
subieboy
 subieboy said:
Hey CHCH ,members, where in CHCH can I take the GTB for its front brake transplant, disk skim (only to remove crap) and complete fluid swap.
How much should I expect as a ball park as I have had 2 quotes at either end of the scale ::)
hy man, im selling my brakes set on tm if u r interested. brakes are very good. only selling as i now have 4pots. http://www.trademe.co.nz/Browse/Listing.aspx?id=414402579
 whatchain']
thanks but have 4pots myself allready
Need a place to do the pads and disks
Update on Quotes around CHCH:
Fit front 4 pots + supplied pads
Fit rear brake pads
Skim rotors (some also quoted worst case to replace all 4)
Replace all brake fluid with Dot4
Labour + incidentals
SafeRBrakes Ltd - $300 + GST ($345 Incl), to replace rotors $75 + GST EACH (front only)
Jamie's Tyre & Auto - $350 + GST ($402.50 Incl), includes replacing front rotors
Advance Automotive - $270 + GST ($310.50 Incl), not quoted for replacement of rotors
Stubaru - $300 + GST (345 Incl), not quoted for replacement of rotors
Leading Edge Automotive - $428 + GST ($492.20 Incl), not quoted for replacement of rotors
Any feedback, used any of the above??
EDIT
Undercar Service Centre - $255.00 + GST ($293.25 Incl), to replace all 4 rotors $438.26 + GST ($503.73 Incl)
Of all those you are probably getting the same parts from the same distributors anyway?
Just go with the best price (or easiest location) as its not like its a highly specialized job, its just something that you may want a professional to do to ensure the brakes are going to work properly afterwards.
Stu is a good man to deal with generally, I've heard good reports from SafeRbrakes, Tony from RDL is my mate so I always support him and Undercar sell decent stuff (some of it just generic, some high quality).
Also, I think you've mentioned living in Rangoon? Have you tried Autotech? Haven't used their services but they're friends with everyone involved at RDL and the owners daughter says hi to me so I like them as well ;D
But in all seriousness, most of those prices are about the same, the parts are going to be pretty much the same and its hard to get the job completely wrong unless they're total muppets :)
Yea live in Sydenham now adays, used to be the goon.
Les does amazing work but a bit far to travel these days. and your right I want a pro to do the work for me not some cunnyfunt.
Will try RDL and I'll drop the hint you sent me :)
 webup']
sorry no, mine are 298mm and rear is circa 290mm
What year is yours? how come you got smaller thinner discs?
Dec 98 The first of the lot of Revision A's, I personally think they were random new & leftover bits models...
My fronts were (are untill next week) 2 pot's on vented disks and the rear are single pot sliding calliper on vented 290mm disks... ???
Have never really been too worried about the diffs in that department in later revisions vs mine, ANd as swinnie said its the same size disk as the WRX rears...
