For Legacy b4 owners - MAF meter
Aaendewy
If own a legacy year between 1999 - 2003, and have an after market pod filter installed, I have a question for you, what kind of Pod filter do you have installed? And do you notice any effects with the Air Flow Meter Sensor?
Additional information:
Recently I've changed two air flow sensors, and noticed that my pod filter causing the sensor to not work correctly, which means a lot of power lost because the sensor can not tell the engine what's going on and so therefore the computer (ECU) doesn't know the amount of petrol etc... to use. I've done abit of research that some after marker pod filter cause the AFM sensor to blow up, if you have a pod filter installed and the sensor works perfectly, I would like to know what brand/type is it. cheers
 ADIKT']
[quote name='ADIKT said:
What afm you using?
Is there such thing as type? Cause all AFM for legacy b4 is the same
Theres a few differant ones..... did it look like this?
Nah those are for wrx sti and maybe forester.. legacy is simple.. as explained above
 Jakee said:
Thats the exact same as my legacy bro. What are you on about?
i agree, i think you need to read up a tad bit more. if you got your pod nice and secure with a bracket etc and your not using oiled filters there must be another more serious fault.
have you tried cleaning your afms with afm cleaner?
checked for codes?
The BE/BH and V5/V6 models run an insert type afm NOT the coloured box ones found in all previous generation legacys/imprezas.
Vibration will be the main killer, im betting your cheap repco filter did not come with a brace to mount to the body?
Personally I cant see the reason of keeping the pod if your just killing AFMs with it. Chances are your not making any extra power and have just increased the chance of detonation.
Yes if your adamant on staying with a pod then I would suggest an Apexi Power Intake. Dry paper element, one of the highest flow rates and better filtration than the likes of a HKS foam filter. Are around $140 via Japan if you get them through 41 Automotive.
I bought an adapter.. there's no air leaking or anything, it's fully secure. I just put in the factory box air flow in yday, hope to last the life of the sensor a little long.. but anyways, i still haven't got any answer for the type of after market filter you guys are using? cause I dont mind spending on the brand filter like HKS etc... but idk if it's any better..
