Threaded Wheel Stud
Flat4
Swapped my wheels over today to the ones that have good tyres on them, since I'm planning on going on a roadie down south tomorrow
One of the studs is threaded on the front right. Has been like this for a while but not as bad
Can I take the car into a tyre shop and have them put a new stud in? Or does it need to go into a mechanic? If so is it a big job?
 MercuryFree said:
Just a matter of loosening the abs ring but yeah makes it a bit more fiddly than otherwise
99% sure from memory that the REARS with abs, cant be done in place by loosening ABS tone wheel
 Ichi Ban']
I did it on my v3 wrx, unsure of other models. Was a pain though!
The handbrake cable spring decided to come off in the process adding time and effort.
I highly doubt you could install extended wheel studs with the ring dangling, but the stockers were ok. I believe I rotated the wheel in between studs because there's only one gap that's big enough.
