1st gear sounds like reverse
Caleb 895/1000
in ze Nissan?
chat to geartech when they reopen, learn to launch in 2nd :P [i have no idea even if it was a subaru]
was gunna hazard a guess it is a straight cut 1st BUT seeing as it never made the noise before : checked fluids?
It happens when you thrash subaru's,(and people love to floor it in 1st & 2nd on turbo engines) mine has a slight wine in second, but nothing to worry about just yet.Once the case hardening of the gears wears (the gear loses its shape), it's really time for a rebuild.
It's pretty much not fixable unless your going to get the gear sets re hardened
Very common on sr20det gearboxes from the years of clutch kicks and drop clutches
Spoke to some gearbox reconditioners and they told be it was either input bearing or lay shaft bearing as I get a whirring on idle with clutch out and whine on acceleration in 1st 2nd and 3rd
Pulled the box down and bearings are fine
First 3 gears are visually worn and you can see the hardening has vanished - its basically back lash creating gear whine on acceleration ( gears are trying to spread apart on load )
Best thing u can do is either put up with the noise - or just get another box and swap it over - I'm on my 2nd Whiney box
  • 4 weeks later...
Yea im guttered as, i was in the middle of trying to get it back... The box is fixed, only cost $186 from geartech... New problem, put it back in and no clutch... The thrust bearing wasnt connected when i got it so i looked a datto box in my mates garage which had a similar set up and cloned that... EPIC fail
