nb : NOT a DIY more a "how I did it"
took me two hours
http://smg.photobucket.com/albums/v427/JoKerNZ/2012/Walbro%20install/
so at 40km shy of 230,000 pump dies on an intersection going to work :/
Step 1 : Identify fault = Pump no go, was getting power, no sound!
Step 2 : Email Brendon @ GFB (see sponsors section) recieve 500 HP pump overnight with fitting kit
Step 3 : Locate pump, under boot floor between rear struts, remove hatch and screws,carefully pull assembly out (after lableing lines)
New and old parts
Filter Sock old
Above is the new pump isolator and below comparison , need to do some trimming with knife
New vs old
Marked for trimming
Above : it fits nice and snug now
Below small hiccup with wiring harness supplied about 4mm too short
Solution cut and crimp wires
below yay no spare parts!
Symptoms of pump dying were slow to start/fire then the obvious failure
all happy now :P
kinda feedback i was looking for : soldering iron was not at my workshop... running risk of fail/used vicegrips for solid connection
was recommended in the "install guide" / documentation
fair enough, soldering and heat shrink is always best.. but your a big boy now :D
