No spound from any speaker
Joker
Cheapie "American Hi Fi" (Made in China LOL) Head deck with Honda loom
unit lights up and locks on station but zero noise
I have a continuity loop from both rear speakers, tried the fade option (cant be arsed right now tearing front cards off to check loop for fronts)
how do I test the output from the Headunit? (continuity loop works right up through the looms to headdeck)
http://www.americanhifi.co.nz/510.html
Check the speakers using a 1.5 v battery can be done behind the head unit,touch the wires from the speakers one at a time and listen for a pop, if no pop then either a/ speakers are buggered or b/ wires are broken
Or you can use your multimeter set on resistance and measure each speaker at the head unit you will be looking for 4 ohms
U can check head unit output by wiring an external speaker in and checking for output ( you must have an old known good one lying around in your junk pile)
