Hard to find First gear
Nick_96_RSB
 kwi_fozze said:
yeah, my clutch is a bit worn and it catches sometimes when warm in first and reverse. found that if you let it drop into neutral, gentle blip on the gas then clutch in again it goes in nicely. its more of.... a feature. lolol
catches ???
what u just explained is what i explained above - by letting the clutch out in neutral your spinning the shafts around in the gearbox - by pushing clutch in again your stopping the gears in a different position which hopingly aligns the gears / synchro better than was aligned before
I clocked up 600 odd k in it between Thursday & Sunday, and it went ok, no problem when driving, just first & reverse can be sticky/crunchy at times, hard for me to tell when its actually engaging properly. all gears will go in fine with car off, as soon as its on the problems show their face
pumping clutch makes no difference whatsoever
I think i will pick up a new slave cylinder for it as a couple of times since i have owned it the pedal has got stuck halfway on return, and from what i have read on the web it seems to generally be the issue
Have sourced a clutch & matching flywheel, just trying to organise cash for it now and fingers crossed all will be good again lol
mechanic at the workshop across the road from my house reckoned it was clutch plate, hes a bit of a muppet, but he owns a subbie himself now, so hopefully he has learned a bit more about them since he put the brake assembly back together wrong in my old mans wagon & i ended up with no brakes heading toward the basin, could have been worse, i could have been going downhill when they failed lol
well i went the drags got there fine and did my first pass fine then when i went to put it back in 3rd it wouldnt let me put it in then i stoped it still wouldnt let me put it any gear so i was pushing it back and foward then it let me into second and then i was fine again and stoped and it would not let me in first but then since those two it hasent done it again
Could be the clutch fork spring fallen off...
Have had similar problems on my 96 rs with 5spd box v5 sti.
wont go into first gear as if its blocked. But for me usually when that happens I put it back to neutral and stick it into first and itll go right in.
As for gearbox oil. if ur not too sure how much goes in there. catch the oil when u drain it and you can measure how much oil came out
Check and see if the adjuster nut that fits on to the clutch pedal from the master cylinder is not coming loose......i had the same issue in my mr2 couple of years ago and it cost me a gearbox coz i had no idea that nut had come loose making it hard to get the car into gear.
  • 1 year later...
Hey, did you ever manage to figure out the problem? I\'m having this same exact issue on my BE5. Flushed my transmission fluid and no difference.
