  • Replies 57
 G-unit said:
only when hard boosting or near 80-100ks
yeh mine was the same, 100ks was a constant shake, over that was a nightmare, had to put up with it while i was up north, now that the hubs been replaced i can go all the way with no vibration at all, the gtb rims probably helped too as im sure my 15s were warped/unbalanced. oh and i replace with brand new rotors before the hub change and it still vibrated so it was definitely the hub for me.
 gen11990 said:
i mentioned a while back about mine shaking, i can confirm it was the wheel bearing, but more so the spline that the bearing slots/sits onto was worn out on the the hub as no matter how much it was tightened it still had play. No bearing noise though. Replaced the whole hub and the shaking dissapeared, hope that helps GF8M8
this is drive flange failure not wheel bearing (the part that press's thru thu middle of the brg
Guys, Haynes workshop manuals are a saviour! only around $50 and could save anyone a whole heap of trouble, I highly recommend them.
 Ichi Ban']
awesome, thanks, its nice to know the actual proper name :)
Nah its more fun to guess at the fault and throw hundreds of dollars of parts at it!! ;D
