What is this diff out of??
forcefed
 madmike said:
Yeah but you can put the stubs into later model diffs too...
I did when i put Funky's diff into my BC5..
So really they could be from anything...
My vote is..
Left = BC
Right= Omega
oh.. do they just pull out, like the stub and seal kit you can get for the front diff on v9+ 6mts?
That being the case, they should just be held in by the normal circlip arrangement on normal male rear axles :)
i'd say you're right - as the old Omega was a 3.9 final - demo can confirm.
Yeah mate...
Thats it...
 funkytown']
My vote is..
Left = BC
Right= Omega
3.9 in the omega/leone is correct ALSO rear of SVX is/was 3.9 :)
The left one looks identical to the 5x R160 diffs in my shed:
Some were out of Legacys and some out of WRXs and yeah mixture of the stub ones and not. I know from experience with a friends car that the stubs sometimes snap off with a good plate diff, but I imagine the stub going inside could also snap off just as easily...
the right one looks like its from a leone, with the mounting bush like that, also look up the hole in the end of the stub shafts and see if there is a torx bolt up there to hold the stub in , if so its definately that era, as said before if its a plate lsd from a rx leone its worth some coin , i have one that i modded to fit the rs.
certainly looks like it has the hole up the centre of the stub axle :) so would also get my vote as being from a Leone ,next question is it a LSD
