Wiring Link Ecu into BD4 NA-Anyone have a pinout??
na_ej25_bd4
 Drunkenmonkey said:
How many plugs it got? Afaik should be the same as a turbo minus few wires for boost solinoid
If it's a 1995 3-plug it's worse than that, you'll have to hunt down correct pinning manually. If it's a 4-plug it should be the same as the single turbos of the era.
It's a 3 plug, which seems to be different to anything else? yea seems to be working out where the wires all go is the only option atm. And doing it because it's high compression and want to see what a non turb suby can do with a decent tune coz the standard motors and tunes are pretty lazy compared to other non turbo brands
Yup, you are going to have to hunt. There are unfortunately two types of 3-plug. That used by the STi and that used by NAs before 1996. The latter shares its pinning with absolutely nothing.
Na i had it on trademe but had no interest so im just carrying on doing work to it, try and chase the title of most powerful ej25 NA in nz? would like to talk to anyone thats done up a non turb before.
Yea its different to the v3/4 3 plug. other way is to pull loom out of my parts car and strip it down and work out exactly where all the wires go?
How many kw did u get? this motor is 11.?:1 compression with rsb heads tho
My personal impression of Subaru NAs is that they're not too shabby. Okay so maybe I'm a bit biased (Own a 2.0 SOHC Impreza that now has an EZ30R in it) but I look at it this way.
1998 Subaru EJ20E, SOHC: 100kW.
2010 Volkswagen Golf GTi: 122kW.
Nissan VQ30DE: 170kW
Subaru EZ30R: 184kW
(both stock)
One of those is a DOHC turbo :/
The other thing is, power can only help you so much, in a straight line sure, it's great... but corners are a great leveller.
If you wanna make an EJ25 awsome I say go for it and let's see how it turns out. You could probably benefit from AVCS though.
