Unexplained rise in fuel consumption ?
clintondane
Our '01 Blitzen is using quite a bit more gas than usual, we usually use about 10.5/11 litres per 100k's but all of a sudden in the last few weeks that has crept closer to 13/100 on a regular basis. Not driving any differently so a bit confused. Gonna put new oil and air filter in next week so hopefully that helps. I have a feeling car is running rich, how much to get it tested and fixed?
Thanks guys.
Thanks guys.
could be a faulty 02 sensor? just a guess
Had that same thought myself, although it was replaced about 40k ago so hoping its not that. Also car hasn't thrown any codes and last time O2 sensor went the CEL light came on. Noticed that after I cleaned the car last time the exhaust tip has got covered in black deposit, almost as if its been blowing smoke but I can never see any smoke even under heavy acceleration. Enigma ? Lol. Possibly spark plug issues?
Turbos run rich anyway under boost
10-12 L is good for open road
12-14 is good for mixed driving
If you are still worried borrow a wide band O2 sensor, or find a mechanic and get some readings.
Another possibility could be some engine knock and its pulling timing = less power per stroke thus less distance travelled for given amount of fuel.
Also try reset the ECU, mabey clear out any codes and relearn the fuel map.
Tyres are always inflated and checked weekly when I put gas in. While the fuel consumption figures listed above are "normal" it doesn't take away from the fact OUR consumption is going up. Sourced a replacement afm for $20, awaiting confirmation tomorrow morning, dependant on codes matching etc. From an '01 B4 so shouldn't be an issue ?
 clintondane said:
Yea may as well try the small things first. Can't find anyone in Dunedin yet that stocks afm cleaner.
CRC Electrical contact cleaner will work too, i think Dick Smith might still stock that. Repco might also.
