Can I run EJ20G manifolds etc on an EJ20K?
filthyrich
Hi guys.... I used the search and found nothing....
I just picked up a donor car with a forged EJ20K
I have a V1 WRX.
I'd like to do a rebuild on the K, and put it in my V1.
Will the V1 / V2 manifolds etc bolt on to the K?
Id like to keep my V1 ECU etc, and do minimal wiring....
Any tips?
Thanks!
manifold pattern is then same ;)
The ej20k heads are deff the ones to use/spend $$$ on but the question i cant answer is if the tune will be safe on the standard ecu with the ej20k heads.
Im sure there's someone on here that has done it before ,
 filthyrich said:
So I could use this:
EJ20K Block
EJ20K heads
EJ20G intake
TD05
EJ20G sensors
EJ20G ECU - retuned
Would I use the COP or the Wasted Spark?
Thanks!
yes to all of the above as for the cop or wasted you could run either its just some simple wiring
 funkytown said:
depends on which heads you use. You will be able to put the v1 heads back on the 20k motor - get the right head gasket and you're away laughing.
From memory the v1 head has a different manifold pattern to v 5/6
Corrected for ya, Any phase 1 head will accept a version 1 to 4.
 Jimbob said:
get some manifold spacers to raise the intercooler pipe above the alternator
that works on late model intakes ...... if you run spacers big enough to clear the alt you will have to never have a bonnet(that closes).
either ac says good bye or use a electronic power steering setup .
or relocate the ac where the battery is ???
not wort it imo
