Digital clock problems?
If you the owner of an Impreza or a Forester and your digital clock is not working please give me a call on 021 231 7761 and I can fix it for you for only $20.
Theres an awesome rant thread on the USMB about the 'Subaru Clock-makers Department'. Apparently they suck at their jobs and clocks rarely last longer than 5 years
Anyone else find it a bit odd that someone decides to sign up, gives no introduction and almost immediately posts stating they can can fix your clock.....but gives no details on how?
I'm here to help if you are not interested that's fine! Once I needed help and I was looking at all Subaru's forums around the world to find a solution!!!
That's not a nice welcome for new members, it's not like you have to.... :)
You need to be able to solder and have some electric knowledge, in some cases you will need to replace electric components but not always so it's really depends...
Have a look around and see how we do things, generally its a better idea to post up a 'how to' thread than this kinda thing
In all honesty it was a pretty bad first thread.
+1 for "how to" thread.
I've done plenty of soldering before and would love to know how to fix this bloody problem.
I've long since relied on my stereo for the time.
Don't know if I am aloud to do this, so if it is frowned upon let me know and I will remove the post.
Copied from: http://ozfoz.com/forum/viewtopic.php?f=24&t=72&p=162&hilit=+clock+fix#p162
 "stumped" said:
stolen from SF, DIY by SenorSubie
Removal of clock:
Examination..
The first thing I noticed was that there was not a direct crack in the
solder.. it was more that the solder got stressed over time so this created
an extremely weak connection, since my clock worked for about 2
seconds here and there
Heres the "to the eye" picture
You may notice that the solder on #510 is pretty pathetic..
Upclose:
Hopefully it didn't turn out too dark, but you can see that it looks like
cottage cheese (sortof) whereas its all pitted
The fix:
Well you have basicly two choices here
1-) Re-solder just using the solder there, basicly using a fine tip solder
"gun" (pencil tip etc) and heating it up, thus allowing the connection to be
uniform
Or (what I did)
2-) Use step one with addition use of solder material, safest way to insure
fix will last awhile
Pictures
Soldering is done.. here are the results..
This picture allows you to see the improvement to the connection
Just a little follow up
The clock works!
and when I was resoldering #510, I decided to do all the other similar
connections, seeing some other ones show'd signs of wear, better safe
than sorry..
If anyone here has a forester clock that's dead I can fix it for a 6-pack of monteiths original!
Mine came broken-After a bit of web work I found some knowhow (subaruforester.org) whipped it out and 20mns later it was glowing green and controlling the day once again.
It's the little square resistors on the back that come off pcb. Just wick off the old solder and reapply.
--sorry I replied to page 1, didn't see the how to----
Looks like the PCB manufacturer didn't do a great job in making those PCBs. Nasty dry joints on those SMD resistors.
Hard to see in the photos, but can't see if the LCD has an external backlight or not. If it does, would be a cool mod to remove it and replace with something like a UV blue backlight!
Or, you could remove the electronics and put a wind-up analog clock in there. ::) ;D
