No heat from heater BH5
lunacy
Hey all
Since having a new longblock put in after the last one cooked itself, we dont seem to be getting any heat through the heater.
I tried bleeding the cooling system this arvo but not sure how effective that was, did seem to be alot of bubbles coming up through the radiator filling point.
The A/C works fine, the blower works, the climate control display works - im kinda at a loss as to what else it could be other than a blocked heater core. This seems strange if it is that, as heater worked fine on previous engine.
Anyone else have any ideas?
 We are borg said:
blocked heater core
at a guess this is what caused last engine to over heat, and if not bypassed/replaced will cause new one to do the same.
Last engine overheated due to one of the metal coolant pipes going to heater core rusting out from the inside and dropping out all the coolant. Mrs didnt know anything about it til it was too late.
 We are borg said:
try a back flush thru the heater core BUT as the first failure was from rust in the system it does not bode well for the heater core
Is there a writeup on how to do this? Car is going in to Winger shortly to have the fuel leak fixed, so wonder if its worth getting this sorted at the same time
BLEED IT!!!!! all you gotta do is turn on the car with the header tank cap off and turn the heater on full heat and wait. top the water up if it goes down. once all bubbles are gone from header tank cap. your done!!
