4 Pots
twinturboboy
yea i\'ve been to give it a go too, currently only have stock single pot front and back so well due for an upgrade.
a couple of things i\'d been wondering were whether LVV certification is needed for something like that, they mention needing it if getting larger rotors but nothing about beefier calipers.
and with regards to ABS and stopping force front and rear ratio, would any changes need to be made there or will it just work it out on its own?
Yea I ask the same question too - I do own two GTB Legacys and one I bought - (which is now for sale) has 4 pots on the front and I noticed on the cert plate it does mention the brakes being different but do you still have to certify it if you change your brakes?
(my car FS can be viewed here: http://www.trademe.co.nz/Browse/Listing.aspx?id=520201469 - It is closed but are offering it for $6200)
 mondo said:
For normal street use they dont offer any better braking, the only thing they will break is your wallet when you need to replace the pads.
Really? Dont think so. If you go for budget brakes you will buy budget brakes. Go to your local supercheap and price up DB1342 and DB1170 pads the latter being 4 pot and I think DB1379 is single pot rear not sure on 2 pot rear. All the same price normally man. IF you gor for bendix or better same applies just you cant buy as gooder pads at the top end for 2/1 pot set ups.
