IAT Sensor on a G4 Link
Stoffa
possible heat soak issue in manifold........However having said that mine is mounted where the PCV used to be under the throttle body and the tuner reckons its no problem.....The book suggests prior to throttle body though....I just wanted to hide mine from the WOF man.
any idea how meth nozzles effect the IAT being mounted close together?
Im toying with the idea of running a TMIC and meth but I would need to mount the IAT in the outlet but I would want to mount the nozzle there as well??
 boon said:
Don\'t you have phenolic spacers? You could probably put it on the intake manifold in that case.
V7 Spec C has an IAT sensor from factory on the manifold and Link say that\'s acceptable to use.
We had thick phenolics aswell, still worked better in the pipework. I wonder if the factory sensor has a plastic body or something like that which isn\'t as thermally conductive add the aftermarket ones? From memory my one it\'s mostly brass?
If you have a close look at the sensing end of the G4 IAT sensor you will see a small bead...This is the connection that makes up this J (Jay) type thermocouple. If this bead bit is in a full air flow area heat soak issues do not apply.
I peeled the plastic off mine so that is more exposed to airflow.....Works well.....Instant responce to air temp regardless of Intake metal work temp....Ceramic coat on manifold also assists.
