exhaust on a TT
RSB
Want to get an exhaust built for my RSB. Have had opinions on where to go already, but am just wondering what the best way to go is.
I'm thinking a 2.5 siamese off the primary, 2.5 off the secondary, and 2.5 from the Y pipe to the back box. I'd like to keep the stock muffler if at all possible.
Thoughts? Is it necessary to do the secondary downpipe?
I want to upgrade the turbos later in the piece to late B4 ones - are these likely to have the same exh housing, or should i do these at the same time?
 JoKer said:
I have B4 turbs and apparently straight bolt in, so I would say exactly the same
I paid to get that service done so that about the end of my knowledge there
Worthwhile upgrade?
IIRC, the blowing the turbo's thing was because they over-spool with a good exhaust. Can't say for sure though, i've no experience with that, and it was a while ago i heard that...
If you do do it, make sure you're boosting all good.
Yeah I have heard the same thing about *ucking the turbos. I got a 2.5 straight through from the Y to a remus tip. Gives it a real sexy rumble ;)
What I did was have a custom mandrel bent one made:
2 & 1/2Inch off the turbo's (immediately into a Cat converter), then into 2 & 1/2Inch Y-join, then into 4Inch flexi, then 3 Inch with another Cat converter (highflow 3Inch type) into 3Inch again all the way out the back into 3 Inch straight through muffler (this is a ADR approved after market V8 Comowhore/falcodore replacement muffler) Mandrel bends all the way.
This way you get the sound, the performance and low Db... All for about $600.00
Whangerei Mufflers did my exhaust.
Yes a large exhaust will kill your primary turbo.
I have a Rage system, 2.5inch (siamese front pipe) front to back which has a much greater exhaust flow compared to the p shooter factory pipes.
The extra flow reduces back pressure allowing turbo to spool faster. Not a huge issue though, just means you need the wastegate to open more.
Take it to someone that knows subs and get it tuned. Pretty sure its just drilling out the brass pill in the vacuum/boost line to the wastegate actuator, this allows it to open more, not sure if anything else needs doing though.
