exhaust types?
does anyone know if the redline exhaust systems are anygood? for a gc8 sti
http://www.trademe.co.nz/motors/car-parts-accessories/subaru/other/auction-562932245.htm
or would it be better to get a rage full system
http://www.trademe.co.nz/Browse/Listing.aspx?id=562788361
or was thinking getting a buddyclub one
http://www.buddyclub.us/~OldSiteContents/buddyclub/muffler/muffler_3_2.html
or would it be better to get one made up from an exhaust shop
thanks
that one bolt is the bottom bolt. spray the s**t out of all the bolts with crc / wd40 before you try to take the old exhaust off. rage systems are LOUD!!!! had one on my skyline and jeebus what a racket.
if you get just a downpipe, or just a cat back, make sure it is guaranteed to bolt up... all kinds of swearing and cursing (and temporary supporting with cableties) will be caused by not properly checking.
Agreed. If it\'s a daily driver, don\'t get the Rage one. I actually just failed a WOF with it sitting at 92db at idle.
 lachlan said:
buy a divocred dump pipe off trade me for 150 . then find a jap cat back for 300 . = good sound and quailty
the buddy club one is likely 4 figures for only a cat back
the rage one is a lot of money for something an exhaust shop could make
http://www.trademe.co.nz/motors/car-parts-accessories/performance/exhaust/auction-564084941.htm
QFT. Also Rage exhausts sound like crap (IMO)
Best gains to be had in preturbo equalised extraction. ;) ;) Down pipe also assists Esp with divorced type/style. However the divorced pipe benefits even more if it is up sized from where the waste gate returns to it :D Go up to 65mm from this point! extend all the way as straight as possible, use a 65mm muffler too...You may also need a mid resonator to reduce cruise speed drone. It will pass Wof no prob and will produce a nice sound on WOT. Ordinary driving will not even turn heads ;) ;) Or bother the coppers! (sleepa car trick)
 B-MAGIC said:
I have blitz nur spec aswell 3" cat back and 3" downpipe, 5" tip no silencer and hav\'nt had any trouble so far ;D. want to get it certed though before any trouble with law :-[ or wof but has been all good so far :) or just buy a genome sti v7 exhaust tip for it and be done with it :-
I have the same setup. Rumble is awesome, savage on boost but not loud enough to get hastled
 bford said:
I had this one installed http://www.trademe.co.nz/motors/car-parts-accessories/subaru/other/auction-567690825.htm Saturday and has a nice rumble without it being to loud.my mechanic did have to cut thread out of old exhaust for sensor and weld it in giant hole they left for it,mabe later models have differant sensor?
I run that system should have been fittings there already to just screw in the sensors bit strange that. Did it fit properly? mine needed shit loads of alterations to fit
 johnny5']
[quote name='bford said:
I had this one installed url]http://www.trademe.co.nz/motors/car-parts-accessories/subaru/other/auction-567690825.htm[/url] Saturday and has a nice rumble without it being to loud.my mechanic did have to cut thread out of old exhaust for sensor and weld it in giant hole they left for it,mabe later models have differant sensor?
I run that system should have been fittings there already to just screw in the sensors bit strange that. Did it fit properly? mine needed s*** loads of alterations to fit
no it all went on well tho needed one alteration to help pull exhaust away from a bolt(just incase senario).the sensor hole looked like they had drilled for another spec or something,now im looking at http://www.trademe.co.nz/Browse/Listing.aspx?id=567808481 to complete,they have another type but not willing to pay twice the price
