Praise the lowered!!!
filthyrich
Aahh, yeah, the auto\'s don\'t like having the spacers removed, things catch on the firewall / transmission tunnel. Throw a set of roll center adjusters to get the same effect as subframe spacer removal\'s effect on the steering geometry. I bet you are fighting a fair bit of bump steer at the moment aye? ;)
 filthyrich said:
Mines rubbing like a bitch. I have removed the inner guard liners, and "massaged" the wheel wells.
I\'m going to try some spacers tomorrow,and get it flusher with the guard.
Wheel / tyre specs? Mine had a whole world of rub with 225/55 17s, nothing with 215/45s, and 225/40s. Check where it\'s rubbing, you might be catching the tyre on the strut.
No just stock springs in foz struts.
Later I ran tein adjusties in rear only height adjust no camber/damper adjustment. Dropped another 10-15mm with keepers in just firmed it up heaps still no rub. That was with stock fronts just wanted to level it off a bit.
