NGK sparkplugs
Hi, 2 things, I need to ask if people can show me where the spark plugs are located in the subaru 2002 b4 twin turbo engine
and also i need some technical advice on if NGK spark plugs are better or HKS spark plugs are better?
spark plugs are located in the sides of the engine... u could say... the have a coil pack on top of them i assume in ur model, you will have to remove itmes like the battary, washer bottle, airfilterbox.
i run HKS spark plugs, dont know if there better than NGK, nothing wrong with NGK.
-smurff
Just get NGKR platinum plugs bro.. part #PFR6G should be around $24-32bucks a plug.. depending on where ya go..
Be prepared to swear and curse getting em out. Unless you got small jappo hands, it can be a mish.
With the right tools, remove as a minimum the air box and the washer bottle. The rest relies on some tight manoevering and lots of bandaids :)
Guest boostcut
ngk are probably the best and most world renowned plugs, they manufacture plugs for other "performance" companys to put their name to... you cant go wrong with a good ol pfr6g platinum plug from repco but as said before be prepared to bend over for them.
 newsuba said:
If you don't know where the plugs are I wouldn't being screwing around with different plugs either.
Take the car to a professional.
+1 If i didn't know where the spark plugs were in my engine i wouldn't be touching anything.
i didn't know where mine where till i replaced them in the foz (knew where they were on a "normal engine")
it's a good small job to diy! easy to diagnose if you mess it up
go platnums or similar (that way you don't have to replace them as often)
 SpotMe said:
Iridiums maybe?
Then again, they may not be worth the expense... anyone have experience with them in the subbys?
In the old forums mate, there was a big discussion between Platinum vs. Coppers vs. Iridiums.. general consensus was i think people preferred Platinums maybe due to longeivity you can get out of them..
 SpotMe said:
Iridiums maybe?
Yeah Platinums (PFR6G) in our RSK. Made quite a noticeable difference when driving - the old plugs must have been a bit on their way out.
 SpotMe said:
Iridiums maybe?
Stuck them in my GT, runs great.
 webup']
[quote name='SpotMe said:
Iridiums maybe?
Hey where did you get them here in chch?
At 90kms should i be thinking about changing them yet?
The manuel say to inspect spark plugs at 100k, but with a Subaru if you have the money and time i would look at doing it when you get your major service (cambelt waterpump etc...)
Iridiums VS platinum
my mate runs iridiums in his BF5 GT, i run platinums in my BF5 GT..
we experimented with them: (this is what we did)
Gap both set to 0.8
Used 3 tanks of petrol (BP 98)
Ran stock 9PSI boost only
Both set of spark plugs where brand new
Iridums set = $110.5
Platinum set = $148.50
First Tank - we drove around off boost and the results were similar, pretty much not a lot of difference, fuel efficiently and drive ability were pretty good
Second Tank - we drove around using boost a bit more, took the cars on a road trip from Wellington to P.North and back (open road remaining constant speed for most of the trip, once again pretty similar, platinum gave a significantly better fuel efficiency (min 25k more to the tank)
Third Tank - Used the car under load, towing a trailer of bikes, platinums where fine, drive well boosted fine etc,... iridiums reduced the smoothness when driving, missed a couple of time and boost was down from the normal, struggle a little bit up the bigger hills but
{** We understand that there are other factors that would influences these results, but just in general the platinum gave the better result **}
The cars come off the shop floor with platinums, why change that? wouldn't Subaru know best for there car / engines ???
Talking with my engine builder/tuner today and he said he's had issues with Iridiums in the past which have been solved by replacing them with Platniums.
Just hoping now that he sold me Platniums last time i changed the plugs :)
 webup']
Iridiums maybe?
I got mine from Repco in Kaiapoi, know someone who knows someone lol, cost $60 for 4 plugs. Reading the other replies im starting to think i should of got the platinum ones... Oh well, the ones that came out were nasty...
 Zerobyte']
Iridiums maybe?
yeah platinums are the way to go mate 8)
You guys have it easy. Add 50% to my bill for spark plugs. Also mine have a MASSIVE long thread on them.
While were on the subject of plugs, whats the general indicator of worn plugs (visual or performance wise)?
Im more used to the old skool thinking where as long as theres some electrode left its all good
Mine was both, performance would be lacking a little, higher fuel consumption and lack of power, boost was playing up / missing...
Visual you could tell me plugs were screw, all had different gap sizes and they we just completely black and caked in deposit, after talking to Armstrong Subaru they said that platinum should last around 125k-150k depending on application and use
 SpotMe']
There had to be some drawback to your flat 6 ;)
Don't forget;
+50% for oil
- 20% power
And no aftermarket parts available.
Oh and its even HARDER to change the plugs than on a 4
 keltik']
Don't forget;
+50% for oil
- 20% power
But on the plus side, it does sound horny....
