Soft spongy brakes
Team
The beast has an issue with soft spongy brakes.
THe fluid has always been kept full. DOT 4 used. Had a minor leak as some muppet left the front left bleed nipple slightly undone, however I digress.
SHould I try a bleed and see how it goes or is there other causes/remedies?
 Rosssub said:
And also tighten the bleeder nut before mate lifts off the pedal as tiny air bubbles can be sucked back in through the threads causing a spongy caliper on that one wheel.
YO... I used to do it that way, but found it is not required... and have found the best way to get rid of stubborn air pockets,
is to just crack a nipple, and pump like fuck... 5 or 6 times... then lock the nipple... still always use two people though.
