??? How can you tell what type of gearbox without the vehicle/engine. The GB has a serial number 824511 but need to know what type eg. 5MT...
if it is out of a EA82 era leone THEN it is a 5 speed dual range part time 4wd as this is the only option for the 4wd models :) UNLESSS you have the AWD box out of a RX but these have a huge vacuum pot mounted to the side to operate the centre diff lock
Thanks for the info and feckety feck. The one I have been sent has a big vacuum pot sticking out the side so must be an AWD. I don\'t mind except I assume this changes all the diff ratios and running AWD of an EA81 will run like pig fan cookies. I don\'t care about performance but the whole exercise was to get fifth gear. Looks like I have an anchor unless anyone local wants to swap for a standard 4WD five speed. (T81G or 5MT?)
