car loses some power when cold? any ideas
alphabet8686
 kwi_fozze said:
Car engine cold? If so, don\'t boot it. You\'ll bugger it.
Absolutely engine doesn\'t run efficiently ie develop full power until it has warmed up, ie most of engine wear occurs when cold so need to take it easy. eg l don\'t exceed 3000rpm until car has warmed up usually sit on 2500rpm (subaru engines develop a reasonable amout of torque at 2500rpm)
If its running cold / slow to warm up the thermostat may be jammed open or may have been removed to cover up overheating issues, if this is the case the heater doesn\'t work / heat very well.
Factory tune is set so it cant be driven hard when not up to temp. Its a safety thing for people um like you obviously. :P Well thats the way I figure it anwyay as my V5 and foz had the same issue till warm. Just feels detuned till comes up to temp.
I\'m not sure if it\'s an ECU controlled thing or if it\'s just the way it is.
Regardless you shouldn\'t be loading the car when its cold unless there is a tsunami or something similar behind you.
I try and even avoid going above 0psi until it\'s warmed up properly.
Are you saying it just feels poor, or it surges unevenly?
All engines are a bit poor when cold - that\'s a given - but a lot of people seem to accept that Subarus will surge and run like crap when cold. They shouldn\'t, it\'s more just a lot of aging parts all playing their part - mine ran terribly cold when I got it but a decent once over of the thing and you wouldn\'t pick a cold motor apart from high idle and no heater haha
Look at afm, O2 sensor age and vacuum leaks primarily
 lachlan']
[quote name='kwi_fozze said:
I try to never go above 0psi until at least 70degrees oil temp. Takes about 15 mins longer than water temp
something is seriously wrong if your oil takes longer to warm up then your water
+1 something is not right if your oil takes 15 mins to warm up to 70 degrees after water has
(price you pay for them* how bad your luck is)/K\'s your car has done + number of cylinders your car has=
length of time (in years, months or days(depending on how bad your luck is)) of how long yor O2 sensor will last.
In all seriousness, they should last for quite a while (between 70,000km- 90,000km), some may crap out prematurely due to random/unlucky issues.
