Loosing water in header tank
tydon
 Eight dollar said:
are you saying the overflow bottle goes up and the engine level goes down?
if so you have an air leak in your system. as the car cools it should bring coolant back into the engine from the overflow
yup overflow fills up leaving header tank witg less water
do a pressure check on that refill/overflow hose/pipe. leak is there somewhere. ??? 2-3 psi will do it. :) sucking air back into system somewhere. This is the only area it can. all others system pipework is under operating pressure of around 0.9 to 1.1 bar and you will see a leak somewhere.......this kind of leak will usually drain the reserve tank not cause it to overfill.
everything seems to be all good again now after changing radiator cap and rebleeding system toopk for a good drive and no loss of water from header tank or any extra going into oveflow yay
 tydon']
If you have a leaking radiator cap then instead of pressurising the system it will just pump it all out the overflow. Pretty simple really.
