V2 sti driveline
94bg5
Ive got a 95 v2 sti wagon with a slipping clutch and dodgey gbox and or diff so I wanna replace from flywheel 2 rear diff.
I found a deal for good condition sf5 s/tb forester parts.
Will they fit? And should I use my shafts or foresters?
That didnt answer my question I wanted 2 know if the parts would fit. By the way wen I had a bc5 with the same gbox in it I was constantly told it was weak . At the mo the sti gearbox seems pretty weak as its already been rebuilt a couple times before I got it and has killed itself again.
So right now I have a 99% straight sti wagon with fresh panel n paint done not long ago taking up driveway space. It needs 2 go with very little money spent
 Eight dollar said:
late model stuff from around 04 does not have offset pin set up - they have a std inner cv with a splined snout
the MY05 6mt box i put in (v9 Spec c) mated perfectly to my MY97 CV\'s. yes its a female box but get the stubs from subaru or an automatic and direct bolt up.
tl:dr its still not a cv nightmare.
